Sparky Posted September 30, 2008 Share Posted September 30, 2008 Hey guys the old man is swapping the heads on my motor but needs the following info: -Torque settings for head boltsTorque sequence for headboltsTiming marksand whatever else requires doingIf anyone has this info could they post it here or even better send the info directly to his email accountBernard2404@aol.comIf you do send it to his email could you please let me know so it saves me sending it againThanks Lewis Quote Link to post Share on other sites
Rich Posted September 30, 2008 Share Posted September 30, 2008 Theres a 5E manual somewhere, shows the torque settings pretty sure they are the same. Timing marks may be different. Quote Link to post Share on other sites
Jozinobi Posted September 30, 2008 Share Posted September 30, 2008 They will be different as the 5E timing belt is slightly different (by few teeth)I was looking into the 4EFTE Power Enterprise x4 Strength Timing Belt but reliable sources told me that it wouldnt fit my 5E.Joz Quote Link to post Share on other sites
Rich Posted September 30, 2008 Share Posted September 30, 2008 Yeah would of thought so as its a taller block. Quote Link to post Share on other sites
Tintin_SR Posted September 30, 2008 Share Posted September 30, 2008 av got a haynes manual kicking about sum-wear Quote Link to post Share on other sites
Sparky Posted September 30, 2008 Author Share Posted September 30, 2008 Dig it out TinTin mate need it ASAP!!! Quote Link to post Share on other sites
StarletRick Posted September 30, 2008 Share Posted September 30, 2008 the timing marks are on the cam gear (big hole with 4e on it, lines up with the dot on the head) and on the crank pulley (little notch in the pulley you line up with the notch on the oil pump) Quote Link to post Share on other sites
Sparky Posted September 30, 2008 Author Share Posted September 30, 2008 Cheers Rick and idea on the torque down sequence and the torque pressure??PLEASE COULD YOU EMAIL THE ANSWERS TO THE ADDRESS IN THE 1ST POST AS I DONT HAVE ACCESS TO A COMPUTER AFTER UNI AND MY DAD NEEDS THE INFO ASAP!!Thanks Quote Link to post Share on other sites
Dave@TM-Developments.com Posted September 30, 2008 Share Posted September 30, 2008 Quote Link to post Share on other sites
Asad Posted September 30, 2008 Share Posted September 30, 2008 May be a tad late but i have a autodata which may have the sequence in....ill be at home tomorrow so ill have a quick look Quote Link to post Share on other sites
Sparky Posted October 11, 2008 Author Share Posted October 11, 2008 Has anyone got the timing information on the actual cam gears (inlet/exhaust gears) that are actually inside the head and the firing order of the cylinders?ASAP!! Quote Link to post Share on other sites
Sparky Posted October 11, 2008 Author Share Posted October 11, 2008 Has anyone got the timing information on the actual cam gears (inlet/exhaust gears) that are actually inside the head and the firing order of the cylinders?ASAP!!BUMP!!!Need this info ASAP so we can get the car finished by tomorrow!!There are a few marks on the back of the cam gears but we are unsure what lines up with what Quote Link to post Share on other sites
