Quite confused about fitment etc, I want phat rims and slammed to the ground but am confused about what fitment etc I need.
How can you work out what width etc you need until you put the wheel on the car and see what it fits like?
I know thats the most nooby question out but just need a push in the right direction.
I have some Momo torque 16" rims on there at the moment but I want a dishyer rim. The V will be dropped on coilies and I will roll the arches. Can anyone help with any of my questions.
I like the look of these but dont know if they will fit.
http://www.wheel-whores.com/classifieds/sh...-g60s&cat=4" onclick="window.open(this.href);return false;
This is what my car looks like atm,
This is what I want it to kinda end up like,
Thanks,
I have Some 16" Rota Cups on my Glanza at the mo they are 8" wide and u will deffo need your arches rolling and possibly flaringon the front.. I decked mine to see how low i could go and i scraped alll over like a bitch! and you will also need a panhard rod!
you will want
some coilvers that can go LOW
some wheels with a low offset
your arches, flaring, pulling, rolling
some massive spacers (hubcentric)
some camber shims
bolt it all on, and go.
then have a lot of extra money for tyres and sumps
*edit* forgot panard rod, youll want an adjustable one
Its a difficult thing to do on a starlet mate! I've got 15x8 et 0 alloys on my car and they are too wide to be dropped cuz the wheels are wider than the wings lol so id say if you wanted it slammed id say go for something like 15x8 et 25 or 15x7 et 10 if you can find them lol, look at idrees , mine or dean rw developments build threads, hope this helps!
Also you defo need your arches rolled!
im planning to do with my 37s, eventualy swapping to some bbs rs
both have +35 offset, but im gonna space them out by like 15mm :ph34r:. make more sense to do it that way to me, as you can then space it out, and move it by getting differnent size spacers
Don't go too low with the offset or you may struggle a little. I have ET10 on the ID-Workz Glanza and there is plenty of work to be done to have the rear arches perfect yet. I have fitted wider front wings so the front wheels sit perfectly without any further modification to the arch.
tbh the starlets are shit for going low... unless you like wheels tucked in your arches get a different car.
you could if you really wanted to persist with a starlet get overfenders, cut the inner arch so you dont scrub... that would allow you to get a low offset wheel i.e ET0 in there without to many issues.
but belive me it isnt as easy as getting coilovers and some 'phat' rims.
P.S. Banded steelies suck balls!
In all honesty to truly run a proper HellaFlush ride, and I'm talking REAL Hellaflush (Not just gettin the wheels close enough and calling it a day) You need to live in a different country :(
Too many people have tried it and just ended up knackering their cars because as soon as you hit a pothole your cars bottomed out.
True hellaflush your talking a cats cock hair distance between the arch and the tyre wall and subsequently just about the same from the skirts to the floor and on our roads that ain't happening :(
You also wont be able to put your foot down anywhere and your car will handle like poo with it having wayy too much negative camber (to fit a nice wide set of rims) And havin a good blast is the spirit of what these cars are all about :(
Please don't take my ranting the wrong way because I love it just as much as the next guy and thought about it myself before I even got my Glanza. True HellaFlush rides are absolute pornnn!!! But I think I'll be leaving this one to the yanks with their wonderfully flat straight roads.... Bastards! haha :lol:
I personally would say if you wanna do it that your best off with 8inch wide wheels with a low offset and a whole lot of stretch, rolling the arches, cutting the inner arch out and then use appropriate sized spacers (if necessary) to get it "flush" and then spend a hell of a lot of time perfecting the stance with the camber and height adjustment of your coilovers. :D
Lol at some of the comments, it really isnt that bad a deal going "hellaflush". Its obvious that some have taken the quick trial and error and got it wrong. The choice of wheel fitment/offset depents on how yo want it to fit. For instance, indrees opt'd for 16x8 et10 wheels which results look great and are slightly further out than my setup so to speak. Which is the reason why his choice of tires are 195 45 r16, it'll make the car look great and stretch may be enough to clear after a rear arch roll. My setup being 16x8 ET20 leaves the rim closer to the coilover, but not as stuck out as his. My tire choice for the front is 225 40 r16 and fits fine with out any bother. The rear is the only issue, due to the way it moves under operation is may tend to come down and move close to the drivers side arch. also most people run meister coilovers, which although its default settings and spring rates are great for the average glanza or starlet, a more tailored setup is required for it all to come together nicely. as most wheels of choice will be wide (i hope no wider than 8j), you need to get the whiteline anti roll bar mostle for the rear. As said, with the right setup you will have no problems and your car will look great. Nothin comes easy, i for one dont know how some peepal have gone to (0 offset), they must be un bareable to drive. be smart, o properly. :wub:
@ Tomtheman2
is this the type of fitment you are after???
looks sexy as dont it :wacko:
Thats exactly what im after! How would i go about doing this? It doesn't seem as extreme as most 'Hella Flush' cars :lol:
there 16x8 ET10 rota grid drifts with a 10mm spacer and 195/45/16 tyres. remeber reading the spec from a few months back :wacko:
Guessing the arches would need to rolled to fit these? (real noob on this type of thing) :lol:
