starlet ryan Posted October 28, 2007 Share Posted October 28, 2007 what would be the best parts to add to give my starlet sr a reliable power increase so as i can show some euro trash where they belong. i already have a good suspension set up and an upgraded break set up which will be done on wed so next is my attention to the engine. Quote Link to post Share on other sites
keirz Posted October 28, 2007 Share Posted October 28, 2007 Firstly, a corolla inlet manifold would be a good buy. when used with a performance filter you will see good gains. also strip the bitch out! best mod i ever done to the n/a i had.i never really experimented with exhausts so i cant really say much on that subject.lightened pullys would be an option too. Quote Link to post Share on other sites
keirz Posted October 28, 2007 Share Posted October 28, 2007 here is a picture for a 4efe intake manifoldits easy to fit you use your own throttle body. so its a case of four bolts to remove your throttle body, a few breathers to diconect and the 5 bolts that hold in on to the block. Quote Link to post Share on other sites
Idrees Posted October 28, 2007 Share Posted October 28, 2007 And you may aswell replace the gaskets while your at it ;) Quote Link to post Share on other sites
Sparky Posted October 28, 2007 Share Posted October 28, 2007 what these guys said ;) ^^^As for the exhaust side I would get a de-cat section made up to iron out the flat spots in the mid range of 1st and 2nd gear mainly But I full exhaust system wouldnt hurt ;) Quote Link to post Share on other sites
scutch0 Posted October 29, 2007 Share Posted October 29, 2007 also run it on some good fuel (take the battery off for 30 mins to let the ecu reset and compensate for the better fuel) also if you feel confident you could advance the timing ever-so-slightly to help you further up the rev range, i did this to great effect with my old n/a (just ask the new owner oli)worked well on fishy's sr too. Quote Link to post Share on other sites
Tintin_SR Posted October 30, 2007 Share Posted October 30, 2007 also run it on some good fuel (take the battery off for 30 mins to let the ecu reset and compensate for the better fuel) also if you feel confident you could advance the timing ever-so-slightly to help you further up the rev range, i did this to great effect with my old n/a (just ask the new owner oli)worked well on fishy's sr too.what is this?? Quote Link to post Share on other sites
scutch0 Posted October 30, 2007 Share Posted October 30, 2007 all you do is slacken off the two bolts that hold the distributor (not the distributor cap) to the head while the car is idling and rotate the whole thing a few degrees either way. one way should increase the revs slightly the other way should decrease the revs. you want to increase the revs, this advances the timing, dont go mad tho, 1-2 degrees of advance is enough other wise the engine will start pinking. hence why you need good fuel. Quote Link to post Share on other sites
Guest Enzo Posted October 30, 2007 Share Posted October 30, 2007 Advancing the ignition timing is an inexpensive mod that can make a noticable difference in throttle response and through the entire powerband with the largest gains in the midrange. fual economey is also improved if your habits remaint he same with aditional power.Ignition timing relates to when the spark plug fires in relation to where the piston is at that poit in the cycle.Timing advance helps produce more power by igniting the sparks sooner, providing more time for the fuel/air mixture to burn completely, increasing cylinder pressure, thus providing more power if the fual is of a higher octain. Quote Link to post Share on other sites
Jozinobi Posted October 30, 2007 Share Posted October 30, 2007 Is there any disadvantage/s to advancing timing? ;)Joz Quote Link to post Share on other sites
Guest Enzo Posted October 30, 2007 Share Posted October 30, 2007 Is there any disadvantage/s to advancing timing? ;)Jozyea there is, too much advance will cause detonation or pinking as the spark will be missing its cycle causing the car to run lean.detonation as we all know is bad for the engine. Quote Link to post Share on other sites
Rich Posted October 30, 2007 Share Posted October 30, 2007 Thinner head gasket to increase compression ratio? Swift gti 1.3s are 101bhp due to the fact that they are 11:1 cr compared to 4e-fe being 9.6:1 (someone correct me if I'm wrong) ;) Quote Link to post Share on other sites
Bourkey Posted October 30, 2007 Share Posted October 30, 2007 Hmmm, I've never heard of this timing mod. I might give it a bash to get a bit more beef!!!!Anyway like people have said the corolla mani is a good option as is a better induction kit but the closed ones are the best apparently. Also use better oil, Spark plugs, Ignition leads and as said, Fuel as well.Another thing you could do is put some engine cleaner in the air inlet. I did this using a mist spray gun and it massivly improved my petrol consumption, perfomance and emissions.As for the exhaust. I used to have a completely free flowing system with no middle box and a sports backbox but i added the middle box back in and it inmproved the performance a little.Also as Kierz has said stripping the car out works really well. I have done it and i'll never go back.Hope this helps. Quote Link to post Share on other sites
scutch0 Posted October 30, 2007 Share Posted October 30, 2007 i kept quiet about advancing the timing because it made such a difference on my old n/a, i wanted to keep it to myself! i finally let the cat out the bag to fishy and adjusted his to which he was well happy, altho his was pinking a little so it needed backing off a tad.it is important to have a good ear for pinking when doing this tho, you only need a few degrees to make a good difference. the other important thing is to run good quality fuel i found my old n/a ate thru spark plugs quite quickly too however.its worth it if you can get it right however. ( i never told geo i had advanced my timing a little on the day of the banzai thrash which made a bit of difference to the times! he he he!) Quote Link to post Share on other sites
RobSR Posted November 2, 2007 Share Posted November 2, 2007 the advanced timing worked a treat on my bros car....like rich said be careful for det. as there was a little as soon as we set off, but it was soon sorted , dont go crazy, and run good fuel....Rob Quote Link to post Share on other sites
Rich Posted November 4, 2007 Share Posted November 4, 2007 To adjust the ignition timing do you need to losen the two bolts that attach the distributor onto the block and move the it around? Quote Link to post Share on other sites
scutch0 Posted November 4, 2007 Share Posted November 4, 2007 yup Quote Link to post Share on other sites
Rich Posted November 4, 2007 Share Posted November 4, 2007 Kool thanks, just making sure I understood it right. Quote Link to post Share on other sites
RobSR Posted November 5, 2007 Share Posted November 5, 2007 mark where it was originally so if you ever want to put it back to normal, you know where it was Rob Quote Link to post Share on other sites
simon22 Posted November 12, 2007 Share Posted November 12, 2007 what other options are there if you want to spend more for a manic high reving n/a? Quote Link to post Share on other sites
SiCaln Posted November 12, 2007 Share Posted November 12, 2007 yea as your man above says in addition little bits that can help are dropping a 5efe engine in to the car, 5efhe cams also help, an apexi air filter is good but easiest, cheapest way is to lose weight (from the car) Quote Link to post Share on other sites
riko666 Posted November 12, 2007 Share Posted November 12, 2007 in a naturally aspirated car there's only so much you can do...no idea how many times I've posted this but whatever, these are typical options:- 5efhe Transplant (or just take the connecting rods, block, pistons, camshafts)- Good Ignition System (Uprated Spark Plugs, Spark Plug wires, Coil)- Proper Lubrication (Correct Oil, freer flowing Oil Filter)- Uprated Radiator (plus coolant additives like Redline Water Wetter)- Corolla Tubular/5efhe ACIS Manifold (port & polish it, extrude hone, ceramic coat...)- Phenolic Intake Manifold Insulator Gasket- 7/4AFE Throttlebody (port & polish it as well...)- Heat-reflective Tape wrapped intake piping and freer flowing airfilter shielded from heat- Tuned Tubular Exhaust Manifold (Ceramic Coated)- Freer Flowing Tuned Diameter Exhaust System- Decat/Freer Flowing Catalytic Converter- 5efhe/Custom Camshafts- Thinner Metal Headgaskets- Lightened Ancillary/Crankshaft Pulleys- Lightweight Flywheel- Headwork (port & polish, extrude honing, x angle valve jobs...)- Lightened & Uprated Valve train (lighter valves, spring retainers, stronger springs)- Lightened Internals (Pistons, Connecting Rods, Crankshaft)- Cylinder Boring (0.5 - 1.0mm overbore)- Internal Friction Reduction (friction coatings & processes on internal components)- Piggyback (eManage) or Standalone (Motec) ECU- Individual Throttle Bodies Quote Link to post Share on other sites
Guest Enzo Posted November 12, 2007 Share Posted November 12, 2007 Thinner head gasket to increase compression ratio? Swift gti 1.3s are 101bhp due to the fact that they are 11:1 cr compared to 4e-fe being 9.6:1 (someone correct me if I'm wrong) yea this is a way of gaining free power, by increasing the compression your making a bigger bang with the same amount of air and fual, is a worthy mod also.ricko covered everything else in regards to custom engine work, which very rarely is worth it for reliability issues. Quote Link to post Share on other sites
Jeremiah Posted June 25, 2016 Share Posted June 25, 2016 Thinner head gasket to increase compression ratio? Swift gti 1.3s are 101bhp due to the fact that they are 11:1 cr compared to 4e-fe being 9.6:1 (someone correct me if I'm wrong) Which thin head gasket should i use in my 4efe natral for power.[ size\convertion] please? I live in Jamaica west indies Quote Link to post Share on other sites
Jeremiah Posted June 28, 2016 Share Posted June 28, 2016 Anybody there? Quote Link to post Share on other sites
