dwd Posted June 9, 2014 Share Posted June 9, 2014 I have a n/a 4efe starlet (Import), I have suspicions that the engine has been changed to a 4efte (running as n/a). Is there anyway I can identify the block and head are 4efte? It has the extra water way between the head and inlet manifold. After a lot of searching, it looks like this was only ever in 4efte heads. Can anyone confirm that this is correct? The other weird thing is it has green injectors, which I don't think is correct either. Its definitely not as powerful as another jdm 4efe I have, I suspect this is due to the low compression of the turbo engine or would the injectors being too small make such a difference? Any info would be greatly appreciated. Quote Link to post Share on other sites
akyakapotter Posted June 9, 2014 Share Posted June 9, 2014 (edited) On the block its self right hand bit that sticks out Edited June 9, 2014 by akyakapotter Quote Link to post Share on other sites
richardc9052 Posted June 9, 2014 Share Posted June 9, 2014 not all jdm 4efe engines are 100bhp.. some n/a's did come with the water port. Quote Link to post Share on other sites
daniel_g Posted June 9, 2014 Share Posted June 9, 2014 The 3rd Gen JDM 4EFE had green injectors and was only like 75 bhp. It had a lean burn map and was built for economy rather power, i had one in a Carat 91 and it was slow as shit. The 1st Gen JDM 4EFE is the one to have.The oil filter bolts straight on the block on the 4EFE, the 4EFTE had 3 studs on the block and the oil filter was relocated to the left a bit. Which is one way to tell. The heads are the same as far as im aware. Quote Link to post Share on other sites
dwd Posted June 9, 2014 Author Share Posted June 9, 2014 Thanks for the help guys. Some useful info there. Do you think if I put pink injectors in that 4efe and an early 100bhp ECU it, would spring some life into it? Quote Link to post Share on other sites
daniel_g Posted June 9, 2014 Share Posted June 9, 2014 Possibly, the ECU will do the most difference, the inlet on the Gen1 looks like a FTE inlet, the exhaust manifold also differs, i doubt the injectors would make a noticeable difference. The Gen3 also had a knock sensor, 4 wire o2 sensor, a corolla style inlet manifold and a DIS ignition system. The Gen1 is a good bit of kit though, i've got the lot here, gonna eventually strap the lot to a 5E and drop it in a GT shell, make a nice N/a daily What JDM 82 do you have, a Soliel ? Quote Link to post Share on other sites
richardc9052 Posted June 9, 2014 Share Posted June 9, 2014 Daniel can you do me a massive favour and post up a pic of the ecu sticker with the codes on etc? Quote Link to post Share on other sites
daniel_g Posted June 9, 2014 Share Posted June 9, 2014 Daniel can you do me a massive favour and post up a pic of the ecu sticker with the codes on etc?There ya go man For reference, out of a 8/1995 EP85. Quote Link to post Share on other sites
dwd Posted June 9, 2014 Author Share Posted June 9, 2014 I have an ECU here that I believe is from 95 JDM 4efeThe codes are89661-10140211000-3030(Black sticker) Anyone know if this is a 100bhp type one? Quote Link to post Share on other sites
dwd Posted June 9, 2014 Author Share Posted June 9, 2014 Daniel the car it was in originally was a 95 (think it was a soliel), has this manifold Quote Link to post Share on other sites
dwd Posted June 9, 2014 Author Share Posted June 9, 2014 The ECU in the car above is89661-10120211000-0540 Quote Link to post Share on other sites
richardc9052 Posted June 9, 2014 Share Posted June 9, 2014 Thanks! We should make a thread that lists jap ecu codes for future reference Quote Link to post Share on other sites
daniel_g Posted June 9, 2014 Share Posted June 9, 2014 Thanks! We should make a thread that lists jap ecu codes for future reference Gen3 JDM 4EFE, DIS ignition, auto Carat EP91 1999. Quote Link to post Share on other sites
richardc9052 Posted June 9, 2014 Share Posted June 9, 2014 I should have an ecu from a gi i can add sooon Quote Link to post Share on other sites
